Check Engine light codes...
Hey guys. My check engine light came on a couple days ago and I finally went to Advance Auto Parts so that they can read out the codes for me. This is exactly what it says on the print out:
DTC (codes)
P0135
O2 Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 1)
P1400
Manfacurer Contrl.
Auxiliary emission
Controls
DTC Pending (Codes)
No Faults Detected.
Does anyone know what this means exactly. What do I need to fix?
DTC (codes)
P0135
O2 Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 1)
P1400
Manfacurer Contrl.
Auxiliary emission
Controls
DTC Pending (Codes)
No Faults Detected.
RE: Check Engine light codes...
did you clear the codes? id reset the battery and see if it comes back on before replacing the 02 sensor. there are 2 the only important one is on the turbo 02 housing, if you look down near the turbo you will see it stocking out through the heat shield with a wire running from it.
