Check Engine light codes...
Old May 1, 2006 | 11:44 PM
agallardo's Avatar
Default Check Engine light codes...
Hey guys. My check engine light came on a couple days ago and I finally went to Advance Auto Parts so that they can read out the codes for me. This is exactly what it says on the print out:
DTC (codes)
P0135
O2 Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 1)
P1400
Manfacurer Contrl.
Auxiliary emission
Controls
DTC Pending (Codes)
No Faults Detected.
Does anyone know what this means exactly. What do I need to fix?
Old May 2, 2006 | 03:43 PM
Default RE: Check Engine light codes...
you need a new 02 sensor. I think that should get rid of both codes. The first code is cuasing the second code.
Old May 2, 2006 | 06:33 PM
agallardo's Avatar
Do you know where that O2 sensor is located? Does that print out tell you enough information to where I can tell where exactly is that O2 sensor located?
Old May 2, 2006 | 08:56 PM
DSMTalonAWD51's Avatar
did you clear the codes? id reset the battery and see if it comes back on before replacing the 02 sensor. there are 2 the only important one is on the turbo 02 housing, if you look down near the turbo you will see it stocking out through the heat shield with a wire running from it.
Old May 2, 2006 | 11:53 PM
agallardo's Avatar
How do I reset the battery? Do I just unplug the battery for awhile?
Old May 3, 2006 | 12:19 AM
yes disconnect the neg terminal for 5 min. if the codes come back the 2nd time you start the car u have a problem
Old May 4, 2006 | 12:18 AM
agallardo's Avatar
Is question is a little bit off this subject. But, IF I purchase a downpipe that replaces the cat, will the "check engine" light come on?
membreya
Apr 18, 2013 12:50 AM
mygst97
Jun 18, 2012 08:59 PM
Montero2001
Jun 13, 2012 08:39 PM
Gstfat
Aug 16, 2008 09:30 AM
spyder4g63t
14
Jul 21, 2008 08:12 PM
