Clutch keeps getting soft
Old Dec 21, 2008 | 06:26 PM
eclipseGS98's Avatar
Default Clutch keeps getting soft
After I bleed the clutch it will be fine until I start it and change gears a few times. Then it gets soft and have to slam it in gear. I replaced the master cylinder already which a mechanic told to me to do but it's still doing it. Any help would be appreciated!!
Old Dec 21, 2008 | 06:40 PM
dsm1990gsx's Avatar
Default RE: Clutch keeps getting soft
Is the slave cylinder leaking?
Old Dec 21, 2008 | 06:59 PM
I do not believe so. The fluid level hasn't moved.
Old Dec 21, 2008 | 07:22 PM
dsm1990gsx's Avatar
Is the clutch master cylinder adjusted properly? Where does the clutch begin to grab at?
Old Dec 21, 2008 | 07:29 PM
It should be adjusted properly. We compared it to the one that came out. And it grabs immediately as soon as you go to let it out. So basically you let it out 1/4" and it grabs enough to stall the engine.
Old Dec 21, 2008 | 10:20 PM
dsm1990gsx's Avatar
I'm wondering that you have it adjusted too much where it grabs right off the floor. That wouldmean the clutch isnt totally disengaging and causing itto shift really hard.
Old Dec 22, 2008 | 06:51 AM
So should I try backing the little U shaped thing out some that connects to the pedal?
Old Dec 22, 2008 | 01:02 PM
dsm1990gsx's Avatar
I'd try it and see what happens.
Old Dec 22, 2008 | 07:54 PM
I would say adjust the clutch pedal. There is a rod that connects to the master cylinder. And on the firewall side of the rod is a bolt, loosen the bolt...turn the rod, tighten the bolt and check the engagement point. I had the same problem with mine and the bolt kept loosening itself up until i really got in there and adjusted the pedal and tightened it up
Harvey32
Jul 21, 2015 10:27 PM
rychehawk
Nov 24, 2008 05:52 PM
dorian7
May 6, 2008 02:23 PM
supercharged3kgt
Dec 25, 2006 08:29 PM
wicked2407
Oct 25, 2006 06:07 PM
