clutch problem
Old Dec 30, 2007 | 01:25 AM
contagious19's Avatar
Default clutch problem
ok its a 95 eagle talon tsi and it wont go in gear. i press the clutch all the way in and it wont go into gear. any help
Old Dec 30, 2007 | 08:29 AM
tjbiker031's Avatar
Default RE: clutch problem
did you check for fluid in resivours? leaks, broken lines, clutch pedal is adjusted correctly.
how did it happen. was it working one day and stoped working or slowly after time.
Old Dec 30, 2007 | 10:45 AM
does it go into gears with the car off? The two types of things im thinking is this
1) if it goes into gear with the car off then its a problem with the clutch not totally disengaging in which you probably just need to adjust the rod behind the pedal.
2) if it doesnt go into gears when the car is off then its a linkage problem so you need to find out where, either at the tranny or at the shifter
Old Dec 30, 2007 | 01:17 PM
nick_200321's Avatar
when you say it wont go into gear, do you mean that by it is grinding or just not going? but i was gonna say damn near EXACTLY what TheEngineer said, only in different words, lol, he got to it before me
Old Dec 30, 2007 | 03:49 PM
oh and to add to the clutch pedal adjustment, if that doesnt do it then it could possibly be the clutch fork (worst case scenario) or the throw out bearing, but if its a throw out bearing youll hear a scrapping noise when depressing the clutch
Old Dec 31, 2007 | 06:22 AM
ok it does go into gear when the car is off, and when da clutch is pressed there is a sound and i was thinking it could be throw out bearing. when da car is on and i pump the clutch it does go into gear but a little hard. the fluid is full and we would bleed da clutch and it worked only once.
Old Dec 31, 2007 | 06:31 AM
yea if you have a sound comming from the tranny when depressing the clutch then its your throw out bearing. Kinda sucks. Now you might as well replace the clutch if its been a while since youve had it done
Old Jan 5, 2008 | 02:34 PM
thanx
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
