clutch problem
does it go into gears with the car off? The two types of things im thinking is this
1) if it goes into gear with the car off then its a problem with the clutch not totally disengaging in which you probably just need to adjust the rod behind the pedal.
2) if it doesnt go into gears when the car is off then its a linkage problem so you need to find out where, either at the tranny or at the shifter
when you say it wont go into gear, do you mean that by it is grinding or just not going? but i was gonna say damn near EXACTLY what TheEngineer said, only in different words, lol, he got to it before me
oh and to add to the clutch pedal adjustment, if that doesnt do it then it could possibly be the clutch fork (worst case scenario) or the throw out bearing, but if its a throw out bearing youll hear a scrapping noise when depressing the clutch
ok it does go into gear when the car is off, and when da clutch is pressed there is a sound and i was thinking it could be throw out bearing. when da car is on and i pump the clutch it does go into gear but a little hard. the fluid is full and we would bleed da clutch and it worked only once.
yea if you have a sound comming from the tranny when depressing the clutch then its your throw out bearing. Kinda sucks. Now you might as well replace the clutch if its been a while since youve had it done
97spydergs
Oct 29, 2007 02:14 PM
wicked2407
Oct 25, 2006 06:07 PM
