clutch slipage?
Old Oct 21, 2007 | 04:27 PM
tjbiker031's Avatar
Default clutch slipage?
ok well when i drive normal or hard at random my car i guess shutters for a second, like my clutch is slipping. mind you that a while back i had a problem with my clutch hydrolic system not hitting the recir valve so it would keep pressure on the clutch pretty much riding it untill i got her fixed. so my question is since my car shutters driving down the road at random, is that my clutch starting to go out?
Old Oct 21, 2007 | 05:21 PM
sk8dudety's Avatar
Default RE: clutch slipage?
i would say if it's shuttering it could even be bad plugsor wires, replace 'em both and see if that fixes the problem
Old Oct 22, 2007 | 06:49 AM
yea you dont get shuttering from a clutch. You only get slipping usually at WOT.
Old Oct 22, 2007 | 05:16 PM
nick_200321's Avatar
yea, clutch slipping would make your rpm's go up and your speed will not... i would think to do as sk8dudety said and replace the plugs n wires
Old Oct 22, 2007 | 07:50 PM
estraw's Avatar
you can get shuttering from a clutch, it usually happens when a little bit of fluid has been smeared onto it. if its only a little bit it causes it to shutter instead of actually slipping. you said you had a problem with the hydraulic system, that might have something to do with that, or you could possibly be leaking oil from your main seal or maybe your trans. there are a few different options to your problem
Old Oct 22, 2007 | 10:15 PM
but the easiest, and still cheap, way to check it the plugs n wires..
Old Oct 22, 2007 | 10:34 PM
estraw's Avatar
well is it a violent shuttering? does it shake the whole car? cause if it does, its prolly not gonna be spark plugs or wires
Old Oct 23, 2007 | 12:10 AM
sk8dudety's Avatar
well let's see what he says about the plugs and wires after he checks 'em, then we'll go from there
Old Oct 26, 2007 | 01:35 PM
tjbiker031's Avatar
yea its not a violent shutter just a noticeable one while driving. ok well ill see what some plugs and wires do.
Old Oct 26, 2007 | 02:03 PM
Natedogg89's Avatar
Sounds like plugs and /or wires
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
