Crankwalk
Old Nov 13, 2006 | 11:44 PM
silvercoupe97's Avatar
Default RE: Crankwalk
What's the boost set at? Hopefully it's set to at least stock level.
Old Nov 14, 2006 | 04:27 AM
racerx55's Avatar
ORIGINAL: silvercoupe97
If you had crankwalk, you would notice noises in the engine bay while or after making a left turn. After making a left hand turn, your clutch would stay on the floor after you pressed it.
thats alot of clearence in a thrust bearing to cause that, holy sh*t, i better check mine out before i waste my time on the topend
Old Nov 14, 2006 | 09:57 AM
Yea thats why with every 7 bolt, becuase of the many occurances of this happening, it lurks over your head with the car. Even if it never happens your always worried it might. Thats why i got rid of mine. I got tired of the stupid things that went wrong and being afraid to beat on it
Old Nov 14, 2006 | 10:00 AM
RCJr9186's Avatar
if you want to be completely safe, get a 6 bolt and a conversion kit!! even if you fix this one or replace it, you still have a chance of the new one or fixed one walkin out on you.
Old Nov 14, 2006 | 10:01 AM
ORIGINAL: RCJr9186
X2
Old Nov 14, 2006 | 10:09 AM
On the topic of crankwalk.....
I don't even worry about it anymore. I have a 6 bolt, but it can still happen. It's no fun worrying about something like that and it may even never happen! Fix it if it breaks or fix it to keep it from breaking, whichever you fancy. Bottom line is that a car is a car, something will always break, doesn't matter who makes it or what's put into it, it's not nor will ever be "bullitproof". If it was or can be made that way, parts companies would be out of business.
Old Nov 14, 2006 | 10:12 AM
RCJr9186's Avatar
true that theoretically it could happen to any car but it's just an unspoken law on here that the 7 bolts are nitorious for it and the 6 bolts are not... as a matter of fact i don't think i've ever heard of anybody walkin the crank in a 6 bolt.
Old Nov 14, 2006 | 11:02 AM
ORIGINAL: RCJr9186
Not many over people even spin bearings.... other than the 3kgt guys cause they always spin bearings kinda like the 7 bolt getting crankwalk lol
Old Nov 14, 2006 | 09:12 PM
Sanguinius's Avatar
Metal on metal sound? Have you taken a timing light to it at all? Sounds like you may have a piston contacting a valve... Trying rotating the engine with the spark plugs out getting each one to TDC and looking through the spark plug hole. See if you can see clean half circle marks that would indicate contact. That would not only give a loss of power but also cause the sound.
Old Nov 14, 2006 | 10:35 PM
BlackMurcielago's Avatar
ORIGINAL: Sanguinius
Okay say is this is the problem. i would have to get a new valve and piston, but what about anythign else. wouldi have to get it sleved or anything else. But yeah there is a mass loss in power. Im goign to go find a timing light gun later
