Crankwalk
Old Nov 15, 2006 | 12:59 AM
  #31
93eclipsegsx's Avatar
Default RE: Crankwalk
well its a built race motor. it costed me 5500 for a short block, head, head gasket and head studs.
Old Nov 15, 2006 | 01:01 AM
  #32
BlackMurcielago's Avatar
so in a nut shell my engine is screwed? What exactly was that a picture of up top
Old Nov 15, 2006 | 01:20 AM
  #33
estraw's Avatar
his spun bearing. he took the oil pan off and thats what he found
Old Nov 15, 2006 | 04:30 AM
  #34
racerx55's Avatar
this is even worse to find than a spun bearing, whats with the surge at idle in that video?
by the way once you spin a bearing youll never get a bearing to last for 10 seconds without turning the crank or replacing it, theres basically no tolerance for imperfections, once the rods beats around on it its out of round & the journal is scarred up and has to be turned if its not smeared up too bad to even be turnable
[IMG]local://upfiles/10240/A86AB43C60B343298ADD108DEC8B7F98.jpg[/IMG]
Old Nov 15, 2006 | 09:45 AM
  #35
depending on how bad your situation is you could be looking at some big bucks to fix it.
Old Nov 15, 2006 | 10:35 AM
  #36
Time for a rebuild
Old Nov 15, 2006 | 12:10 PM
  #37
RCJr9186's Avatar
orrrr a 6 bolt lol
Old Nov 15, 2006 | 03:00 PM
  #38
ORIGINAL: racerx55
i had a bad IAC so thats why it was doing it.
Old Nov 15, 2006 | 08:35 PM
  #39
Sanguinius's Avatar
A spun bearing isn't the end of the world. It's an easy fix for someone that knows what they're doing. You can do it with the engine still in the car if I'm not mistaken. BUT you have to know what you're doing. If I were in the position you're in I'd be looking at diong a bulletproof lower end build. Replace the crank, rods, and pistons with higher end performance parts. But that's just me.
Old Nov 15, 2006 | 10:12 PM
  #40
ORIGINAL: Sanguinius
thats what im saying
a spun bearing can be the end of the motor very easily though... Keiths stealth had a spun bearing and it trashed the turbos and heads BADLLLYYYYYYYYYY needed to buy a new motor\head\turbos too bad it just spun another bearing again though ouch!!
