Eclipse 99 clutch problem
Old Mar 23, 2009 | 03:54 PM
EclipseRS_99's Avatar
Default Eclipse 99 clutch problem
Hi guys, I'm new to the forums,......I have two babies, my beloved 99 mitsubishi eclipse RS and my 03 Infiniti FX RWD. my eclipse was running just fine, but today when I started it to go to the groceries store the clutch was not working. The first thing I noticed is that there was not pressure when I push the pedal. Then I saw some kind of stain on the pedal and then I checked the clutch fluid and there was nothing in there, it was dry. So bought a bottle with clutch fluid and filled the empty container. Now I don't know what to do...I was wondering if I have to replace the clutch which is going to be a real PITA and a lot of money. O r if it could be something else that it not letting the clutch work properly.
Thanks in advance for your help guys.
here some picks of my two babies
Old Mar 23, 2009 | 06:50 PM
Sounds like its the master cylinder
Old Mar 24, 2009 | 01:34 AM
estraw's Avatar
definitely your master cylinder. its leaking through the firewall, thats why you have the stain on the pedal and your reservoir was empty
nice fx btw
Old Mar 24, 2009 | 05:46 AM
thanks guys that cleared up a bounch,.....now I would like to know if it is a real PITA to replace the master & salve cylinder by myself, becuse I can't move the car since the clutch is not working...........and if I take it to a mechanic how much something like this should cost.
Old Mar 24, 2009 | 08:39 AM
you should be able to do it, its fairy easy since its right there at the pedal. You would be better off to buy a haynes manual and that will give you full step by step instructions because you will also need to bleed the system afterwards and that will tell you how
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
