eclipse gst engine build
Old May 18, 2009 | 11:40 PM
caseclipsegst's Avatar
Default eclipse gst engine build
hey guys im lookin to rebuild the engine in my gst... im lookin to make around 300 to 350hp ... what would yall recommend as far as parts and such.. im am going to be running the big 16g turbo... please if you could make me a parts list that would be able to handle the 300 to 350hp range, any input would be greatly appreciated,thanks
Old May 19, 2009 | 07:10 AM
The stock motor can handle that power. So anything additional is just insurance
Old May 19, 2009 | 01:34 PM
ok, but if i was to upgrade some of the internals what would you recommend i go with
Old May 19, 2009 | 03:46 PM
well there are plenty of good brands out there for forged internals. Eagle or crower rods are fine and also wiseco, ross, or JE are good for pistons. Then of course ARP for the main and head studs
Old May 19, 2009 | 04:34 PM
dsm1990gsx's Avatar
The stock 6 bolt engine can handle 450 hp easy w/ a good tune, the 7 bolt can handle abt 425 hp. There is a guy in my area that put 580 hp on the stock 6 bolt engine.
I would suggest leaving your engine in the car as long as its in good condition and look around for a 6 bolt and build that.
Old Jun 4, 2009 | 03:42 AM
Kyle D32a's Avatar
You could always do a stock rebuild "if the motor is in need of one" and then just make sure to get new gaskets.. oem gaskets are probably what you want.. and make sure to get ARP head and main studs.. then you should be good for the amount of power you are looking to put down.
If you want anything higher than about 400+ you will need to start getting into forged internals such as rods, pistons, etc.
gst4me
Aug 17, 2007 02:07 AM
TheEngineer
Jan 13, 2007 03:26 AM
Sanguinius
Other Mitsubishi Models
Jan 3, 2007 08:33 PM
bagz
1st Generation
Jun 6, 2006 08:25 PM
paintballproam
May 21, 2006 11:44 PM
