is this an electrical problem?
Old Feb 4, 2007 | 01:24 PM
BrunoBoy650's Avatar
Default is this an electrical problem?
ok on my 96 gsx, i can roll the sunroof back, but when i push the switch to close it, itll go about 3/4 of the way and then stop and roll back open again. its weird, but it only does it sometimes, and when it does it and i get it to close, it makes a *pop* noise when it shuts. im so confused, what do you think it is? and if i have to replace the sunroof how much do you think it is?
Old Feb 4, 2007 | 01:31 PM
I Drive Naked's Avatar
Default RE: is this an electrical problem?
I may be the switch or the motor.
I had a cars driver window do that to me, and it ended up being the window motor.
Old Feb 4, 2007 | 01:35 PM
93eclipsegsx's Avatar
man you really must want to get this thing fixed, you have this posted on buschur's forums as well.
Old Feb 4, 2007 | 07:35 PM
ORIGINAL: 93eclipsegsx
lol thanks
Old Feb 14, 2007 | 02:39 AM
mtdahl's Avatar
sounds like it is coming out of the track. There is a safety in it to make it return to open if it binds up ie. a childs head or hand in the way. The pop you hear is it going back into the track. Check to see if the track is bent or broken.
Old Feb 14, 2007 | 09:49 AM
I had the EXACT same problem with my sunroof on my talon and the problem ended up being that a plastic peice on one side broke. I thinkit was just a connector in there or something but i think thats what was causing mine to do it every now and then. And i would have to sit there and keep hitting open till it didnt get cuaght. I would just check both sides of the sunroof just to see if anything is different from one side to the other.
Old Feb 15, 2007 | 03:08 AM
thanks guys, its funny, if it does it, i kinda have my hand pushing it close as i close it and it seems to close without me forcing it. =/
Old Feb 15, 2007 | 03:47 PM
jerusry's Avatar
well, engineer... i had the same exact problem and still do! get it fixed asap... or it might run off the track.. mine did, and now it won't close 1?4 of an inch on one side! it doesn't leak.. but when you look at it makes it lok kinda cheap =(
poiz
Apr 25, 2006 02:26 PM
poiz
Oct 17, 2005 07:30 PM
Bakesale420
Sep 8, 2005 02:44 PM
9498jl
1st Generation
Jul 12, 2005 01:31 PM
HoloSkull
Sep 13, 2004 12:17 PM
