electrical problems
Old Oct 11, 2005 | 11:10 PM
georgegsx's Avatar
Default electrical problems
ok i have a problem my turn signals dont work and my gauges dont work either, i dont have any interor lights either. i cant figure out my problem i checked every fuses and relay and flasher!!!!!!!!! THE CAR RUNS FINE THO. I NEED HELP!!!!
Old Oct 11, 2005 | 11:41 PM
Default RE: electrical problems
it is a fuse for sure. what year car is it? I did that in my 00 GS and it was a fuse in the interior fuse panel all the same stuff didnt work. look in the owners manual and figure out which fuses are for that stuff and replace them even if they look fine. then you can rule out the fuses. also did you take apart your dash at all to do any work before this happened? Make sure your dimmer switch is plugged in behind the dash that will cause a very similar problem as I have done that in my EVO
Old Oct 12, 2005 | 01:24 AM
Sanguinius's Avatar
It's also a posibility that the dimmer is going bad. Also when you say you lose gauges are you merely losing the lighting on them or do they cease to function altogether? Check all fuses replacing any related to interior and lighting. Also check your fuses under the hood.
Old Oct 12, 2005 | 05:46 PM
georgegsx's Avatar
the gauges dont work peroid the the rpm,speed,gas,turbo,oilpressure all sit on the bottom. the light dont turn on i have replaced all the fuses and flasher and realys... i can not figure it out..
Old Oct 12, 2005 | 06:33 PM
Sanguinius's Avatar
K now you're into a WHOLE nother area that I don't know MUCH about (Trust me I'm still plugging away trying to figure out my Mom's dodge I keep getting a no bus error but the car runs and drives the guages wipers and locks don't work when the no bus error happens but it's intermittent it on;y happens on warm days)
jp2000
Jan 1, 2012 05:21 PM
danawebb
Feb 28, 2007 07:16 PM
emssniper
1st Generation
Mar 13, 2006 11:51 PM
Ryan
Jan 25, 2006 03:06 PM
06EclipseGT
Jul 5, 2005 09:55 PM
