Electrical Problems !?!?
Old Jan 25, 2006 | 10:40 AM
Ryan's Avatar
Default Electrical Problems !?!?
Hey I drive a 2000 Mitsubishi Eclipse Gt. I put an after market head unit in and took out my stock amp and reran the speaker wire back to behind the dash. But the problem is. Now I hooked up my Stereo and it doesn' t turn on and my sunroof won't open my emergency Flashers don't work with the key off and my power locks won't work with the key off. The interior lights on the mirror won't turn on. It's all things that should have a hot line to it at all times with or without the key. I've checked all fuses. But I know nothing about Relays could it be one of these???? If not what else could I check???
Old Jan 25, 2006 | 10:57 AM
eclipsed4u's Avatar
Default RE: Electrical Problems !?!?
damn man...you ****ed something up.
did you check both fuse boxes?
Old Jan 25, 2006 | 01:27 PM
brandoN^gsT's Avatar
Did you cap off ALL of the wires on the headunit? Make sure there are no wires loose. If any of them are touching metal, they're going to give you those electrical problems...Well...Not all of them will give you THAT electrical problem, but you know what I mean I've had problems with the illumination wire before. My dash lights, and my rear night lights didn't work. So, make sure everything is nice and capped off.
-brandoN^-
Old Jan 25, 2006 | 03:06 PM
Sanguinius's Avatar
Not only that but check wires in the area and make sure you didn't clip any accidentally when trying to take the head unit out. If you even nicked one it could be causing a ground.
jp2000
Jan 1, 2012 05:21 PM
danawebb
Feb 28, 2007 07:16 PM
emssniper
1st Generation
Mar 13, 2006 11:51 PM
georgegsx
Oct 12, 2005 06:33 PM
06EclipseGT
Jul 5, 2005 09:55 PM
