Engine fan
Old Mar 12, 2007 | 07:34 PM
Default RE: Engine fan
im just as clueless as you are on this. Ive never had to deal with the wiring on these. If i still had one to look at i could tell ya.
Old Mar 12, 2007 | 10:39 PM
silvercoupe97's Avatar
I think it's time for a test light and a battery. I tried finding the wiring info through my E-manual but there's a lot of info in them and it's hard to find that kinda thing.
Since the wires fell and burned the insulation, the wires probably shorted out and burn the fan motor or something worse down the line.
Use a 12v battery to see if the fan is still operable and use the test light to see if you get 12v on the original wires that were connected. A multimeter would be better though, so that you can check the ground or check for the ground wire.
Old Mar 12, 2007 | 11:19 PM
50ul }{4ck3r's Avatar
it works when i plug it to the battery.....i found the postive with a test light.....but need to know what wire is negtive
Old Mar 13, 2007 | 12:38 AM
No need to give yourself a headache over finding the ground, seriously. Make your own ground or use a multimeter to find the ground wire.
Old Mar 13, 2007 | 10:02 AM
RCJr9186's Avatar
hell yea dude, tie or screw that sucker to the chasis and call it a day! lol
jrudolph
May 1, 2011 12:40 PM
bolide
May 16, 2008 11:16 AM
jabawaki
Jun 22, 2004 10:16 AM
Eclipse01
Nov 25, 2003 12:12 PM
98NCKBRKR
May 30, 2003 09:49 AM
