Engine revs and then chokes out
Old May 17, 2007 | 07:50 AM
figaro425's Avatar
Default Engine revs and then chokes out
I recently had my fuel filter replaced on a 95 eclipse gs. Since then the car starts rough and runs for about 3 minutes, after which the engine rpms bounce up and down till it sputters out and won't run at idle. There is a modified air intake on the car, and I was wondering if with the clean fuel filter should the idle speed be adjusted up to compensate.
Old May 17, 2007 | 07:53 AM
Dusty Eclipse's Avatar
Default RE: Engine revs and then chokes out
Sounds like it was a bad install of some sort... you smell any leaks?
Old May 17, 2007 | 08:29 AM
figaro425's Avatar
no I dont smell any leaks.
Old May 17, 2007 | 09:03 AM
It only runs like hell once its warmed up?
Old May 17, 2007 | 09:07 AM
Air leak he meant
Old May 17, 2007 | 09:39 AM
figaro425's Avatar
yes, once it warms up it starts to run poorly.
Old May 17, 2007 | 10:39 AM
Possibly a gasket or something, or so it seems... maybe once the engine warms up and the gaskets get a little gooier and stretchier a breach is occuring. Sounds like some kind of unmetered air reaching the motor. Some kind of vacuum test is in order Id say.
Old May 17, 2007 | 11:07 AM
TheAdvocate's Avatar
Could be your idle control valve..
Old May 17, 2007 | 12:30 PM
If it was the diel air control valve then it wouldnt stall out.
Raquel
Mar 26, 2011 11:03 AM
keith 1
Jan 7, 2009 09:22 AM
rexbd
Jan 29, 2008 07:18 PM
dorian7
Aug 10, 2007 04:02 PM
