Engine swap CEL???
Old Aug 7, 2008 | 03:10 AM
silvercoupe97's Avatar
Default RE: Engine swap CEL???
You may want to swap in the 97 ECU too. If you swapped in the entire motor with all the sensors, then you have a motor tuned for (and vice versa) with a 97 ECU.
Old Aug 7, 2008 | 03:11 AM
They did something to the 97+ that they didn't in 95+96 with either emissions or timing/fuel...or you could check all the sensors and make sure they resemble the 95-96 factory specs.
Old Aug 7, 2008 | 11:31 AM
i would start by cleaning the throttle body and ISC (idle speed control) because that code has to do with the idle. Also try and adjust the BISS if your idling alittle to high or low
dlx_11
Nov 23, 2012 09:48 AM
mysterio2099
Apr 5, 2006 04:22 PM
brandoN^gsT
Jan 27, 2006 02:36 PM
305RS97
Aug 30, 2005 10:23 PM
mitsu23
Oct 30, 2003 11:56 PM
