evo 3 or 4 head on a gst block
Old Mar 4, 2008 | 12:11 PM
clips69's Avatar
Default evo 3 or 4 head on a gst block
im currently swaping out my 2g head cause they say the ports on the evo head are bigger than the 2g for more air flow...but only have the bare head...so i have two questions:
1.would the evo head bolt directly to the gst engine?
2.would the gst head-cams, valves, rollekers...etc fit into the evo head?
Old Mar 4, 2008 | 12:55 PM
sk8dudety's Avatar
Default RE: evo 3 or 4 head on a gst block
i'm not sure you can use an evo head cause the engine is flipped around on the evo... but i could be wrong... and why wouldnt you just get ur current head ported and polished then built? it'd be cheaper than buying an evo head and doin the same
Old Mar 4, 2008 | 01:13 PM
I agree with him. And what kinda mods are you trying to do, and HP that you are worried about the flow capacity of the stock head?
Old Mar 4, 2008 | 02:49 PM
Rob's Avatar
Rob
The Evo I-III head is the same as dsm's. Not sure about the internals, but the I-III Evo head fits.
Old Mar 4, 2008 | 04:05 PM
RCJr9186's Avatar
how much are you trying to spend on the head?
for probably about 1k or so you could build a pretty nasty head to flow 700+whp.
Old Mar 4, 2008 | 08:42 PM
clips69's Avatar
well the evo head was free...not really trying to get big hp gain...jus thought if swapping the heads might increase air flow...but thanks for info
Old Mar 5, 2008 | 06:49 AM
dsm1990gsx's Avatar
What rob said is right, evo 1-3 heads will work on your 2gen. Which evo did you get the free head from?
dorian7
Jan 22, 2008 06:09 PM
ttenn
Jun 10, 2006 01:45 AM
frakinstine
Nov 4, 2005 02:02 AM
frakinstine
Nov 1, 2005 03:25 PM
Waters411
1st Generation
Jun 27, 2005 10:18 AM
