guzziling sound
I think I know what you're talking about...It almost sounds like something is grinding, or boiling...I can't put my finger on it, but when I let up off the gas, and the clutch, I get that wierd noise....hmmm. Anyone?
I have the same probelm and I know 2 things that it might be. One could be that the syncro's are not blocking the gears from slightly rubbing together or that the bearing right were the Shaft enters the trans. is bad. But there are other things it could be. Now this is if your refering to a grinding noise. Mine started right after my clutch was shreaded to crap. I just plan on replacing the trans.
5star
Oct 23, 2007 09:58 AM
