Head Gasket 420a
Assuming you how to replace the head gasket in the first place (not for hobbyists) label your vaccuum lines, have a torque wrench on hand, a shop vac to make sure no dirt or debris falls in the cylinders, wire brush to buff away any loose dirt, wash the engine with a degreaser first, let dry, disconnect battery cables and remove from under hood etc.
dopeysw20
Oct 12, 2011 09:06 PM
420a, change, engin, engine, forum, gasket, head, headers, headgasket, mitsubishi, removal, remove, replace, replacement, replacing
