Internal Lounge Chat about beefing up your insides here.
Head gasket r/p question
Old Mar 15, 2005 | 01:58 AM
TheMongoose's Avatar
Default Head gasket r/p question
Ok, so I have this infamous head gasket leak on my '98 Eclipse with the Dodge 2.0 NA motor. For any of you that have repaired this did you have to do the water pump at the same time? Does it make sense to do it while you're in there? I am planning to do the timing belt. Thought that a new one might wear out the water pump bearing if I didn't cange it out. What do you guys think?
Old Mar 15, 2005 | 04:19 AM
dsm king's Avatar
Default RE: Head gasket r/p question
Yeah it would definitly be a good idea to replace the water pump and timing belt at the same time, preventitive maintinance is always a good thing.
Old Mar 15, 2005 | 07:18 PM
vertstanggt's Avatar
If you've got the cash do them both, also while you're in there check out the condition of the valves and all of that. Have fun and good luck with that, hope you get it up and running soon.
Old Mar 23, 2005 | 05:42 PM
Dans Talon's Avatar
Don't forget to re-torque that head after 500mi.
Then maybe it won't leak again eh ? DT
I Drive Naked
Feb 7, 2007 08:23 PM
TheMongoose
Apr 13, 2005 01:26 AM
chrisg
Mar 29, 2005 06:42 PM
XskiesoffireX
Mar 16, 2005 12:32 AM
red92eclipse
Oct 22, 2004 12:38 PM
