HELP!!!!! 1 more time
Old Jul 25, 2007 | 11:18 PM
claytonkobe's Avatar
Default HELP!!!!! 1 more time
1997 Eclipse GS, All stock
Ok, so, last time I had this problem, we fixed it by changing the Crank Position Sensor. So now this is the deal.....
Car ran fine. Started overheating again, but did NOT overheat, but upon checking everything, the system needed a simple flush. So i turned off the car, drained the radiator, added the flush and tried to start it. It wouldn't start. Figuring I ruined the new CP Sensor, so i changed it again, and still no fire. Has compression, but the only thing its driving is ME, INSANE!!!!
HELP, Pretty please.......
Old Jul 26, 2007 | 04:15 AM
silvercoupe97's Avatar
Default RE: HELP!!!!! 1 more time
So was your car really overheating or was the sensor showing wrong?
You may have to change the cam sensor too.
Does it attempt to crank over at all or is it just dead? Are you getting fuel? Also, change out the ASD relay and get back with us.
Old Jul 26, 2007 | 12:52 PM
It started to overheat. I shut it down. I was thinking maybe the cam sensor, but I didnt want to replace hella stuff before i knew what the hell was up. It gets fuel, turns over and almost starts. It will chug into a start and then right back to cranking, similar to when its out of fuel, but it has both fuel and spark.
Old Jul 27, 2007 | 01:23 PM
*bump*
hostl
Jul 10, 2006 10:34 PM
estraw
18
Dec 15, 2005 06:47 AM
Xavsbud
Nov 9, 2005 05:15 PM
bigred4life
Nov 4, 2005 10:42 PM
