How Much....Engine Rebuild
Old 01-23-2007 | 11:32 PM
50ul }{4ck3r's Avatar
Default How Much....Engine Rebuild
i am trying to figure out about...how much would it cost to rebuild my
4g63 Engine
for everything to rebuild my engine
Old 01-24-2007 | 09:45 AM
5Tizzle's Avatar
Default RE: How Much....Engine Rebuild
if you have a stock block, get a 6 bolt and rebuild that. block=300ish bucks, rebuild stuff(just for block)=400ish bucks
Old 01-24-2007 | 09:46 AM
5Tizzle's Avatar
and getting the block machined will cost about 100 bucks
Old 01-24-2007 | 11:25 AM
RCJr9186's Avatar
agreed... if you are going to rebuild a 2g bottom end... invest in the 6 bolt... if not you will always be driving around and every sound you hear will be the sound of possible destruction called crankwalk. you can pick up a block feom 200 -1200 (built) but if you buy it bare, hot tank it - 50 bucks, bored cylinders - 75 bucks, pistons - apx 350, rods - apx 300, main and rod bearings - 80 for both. if you have a crank... its only about 100 to have it knife edged (depending on how serious you are about your car) and while your at it, go for a cometic head gasket to ensure you'll never blow it!
AznLibra929
08-06-2007 09:45 PM
MoMoney57
11-01-2006 03:09 AM
WhiteTrash93
1st Generation
17
06-06-2006 12:30 AM
gst4me
05-18-2006 04:42 PM
m3kgt_99
01-31-2006 06:25 PM
