How Much....Engine Rebuild
Old Jan 23, 2007 | 10:32 PM
50ul }{4ck3r's Avatar
Default How Much....Engine Rebuild
i am trying to figure out about...how much would it cost to rebuild my
4g63 Engine
for everything to rebuild my engine
Old Jan 24, 2007 | 08:45 AM
5Tizzle's Avatar
Default RE: How Much....Engine Rebuild
if you have a stock block, get a 6 bolt and rebuild that. block=300ish bucks, rebuild stuff(just for block)=400ish bucks
Old Jan 24, 2007 | 08:46 AM
5Tizzle's Avatar
and getting the block machined will cost about 100 bucks
Old Jan 24, 2007 | 10:25 AM
RCJr9186's Avatar
agreed... if you are going to rebuild a 2g bottom end... invest in the 6 bolt... if not you will always be driving around and every sound you hear will be the sound of possible destruction called crankwalk. you can pick up a block feom 200 -1200 (built) but if you buy it bare, hot tank it - 50 bucks, bored cylinders - 75 bucks, pistons - apx 350, rods - apx 300, main and rod bearings - 80 for both. if you have a crank... its only about 100 to have it knife edged (depending on how serious you are about your car) and while your at it, go for a cometic head gasket to ensure you'll never blow it!
AznLibra929
Aug 6, 2007 08:45 PM
MoMoney57
Nov 1, 2006 02:09 AM
WhiteTrash93
1st Generation
17
Jun 5, 2006 11:30 PM
gst4me
May 18, 2006 03:42 PM
m3kgt_99
Jan 31, 2006 05:25 PM
