Idle Problem
Old Feb 16, 2006 | 08:21 PM
chrismckitt's Avatar
Default Idle Problem
I have a 95 Eclipse GS and my speedometer quit working, so I replaced the VSS which didn't fix the problem because the gear in the manual tranny is worn out, but anyways after the speedometer quit working I started geting a check engline light. I read the code and it said my IAC was bad, so I replaced it. The problem still exists and I was reading some where that the IAC resets itself at a certain speed. So if my speedometer is not working and the ECU is not getting a speed signal then it wont reset and idle correctly? Please help!!!!!!!!!!
Old Feb 16, 2006 | 08:57 PM
Sanguinius's Avatar
Default RE: Idle Problem
Sounds about right... You might want to see about getting the speedo gear fixed... If not for wanting to know how fast you're going for the fact that it's kinda necessary (At least out here cuz you need it for inspection lol)
yamahablaster8230
Aug 29, 2006 09:28 AM
RCJr9186
Jan 2, 2006 06:32 PM
rbland
Oct 7, 2004 04:16 AM
VR4Restored
Aug 14, 2004 01:09 AM
1rippinGT
Mar 24, 2004 01:38 PM
