intake solutions in a 4g63
Old Oct 6, 2005 | 04:31 PM
derf's Avatar
Default intake solutions in a 4g63
i've got a 95 eagle talon tsi, and i threw on a custom intake with a k&n filter. I went to test, and i got a MAF code... [:@]
I actually tried replacing the MAF, and it still threw the code... So I returned to the stock intake...and cried on the inside a little... does anyone know what the hell my car's bitching about?
Old Oct 6, 2005 | 04:59 PM
eclipsed4u's Avatar
Default RE: intake solutions in a 4g63
when you put on your custom intake, did you hook the MAF sensor back up?
Old Oct 6, 2005 | 05:13 PM
derf's Avatar
yea, i hooked it back up with both MAF's... it just wouldn't idle right... it would start, idle really low, then die...
i even ended up burning my front O2 sensor somehow....so i replaced that... it's been a big mess for something so simple...
pretty discouraging
Old Oct 6, 2005 | 06:56 PM
Sanguinius's Avatar
Sounds like a problem with the maf inputs/ECU somewhere. Need to get a datalogger and see the MAF readings see what they're doing. Sounds like the MAF sensor is telling the engine it's getting a hell of alot of air thus making the ECU dump extra fuel to compensate which puts out more carbon and thus clogs up the O2 sensor.
Old Oct 7, 2005 | 02:14 PM
DSMTalonAWD51's Avatar
tell us what intake you bought. where did you hook it on, directly to the turbo? or the maf black box? alll you need for an eclipse is an air filter/adapter for $60 and it should be fine
Old Oct 7, 2005 | 06:14 PM
Sanguinius's Avatar
Good point hand't thought of THAT one. I assumed he had everything how and where it needed to eb but I guess I shouldn't really assume that eh?
Old Oct 8, 2005 | 01:37 AM
derf's Avatar
i bought a metal plate that bolted directly to the MAF, and it was a K&N filter...i don't remember the manu of the adapter plate...
Old Oct 8, 2005 | 10:07 AM
It sounds like either the MAF isnt installed right or you didnt hook up you BOV to recirc back into the intake like it should. Are you VTA or recirc. if the BOV doesnt recirc it can throw a code and the idle will bounce. did you remove any of the upper IC pipe to install it you also could have a leak.
I have a custom made intake on the EVO had a bouning idle and a check engine light when I was VTA untill I made a dump off for it now it runs fine.
Here is a few pic of my intake and how I recirc'd the BOV I just welded in a small pipe into the bottom of the intake
[IMG]local://upfiles/3652/75F0A837C2474C6CBF03BC2B6F18E386.jpg[/IMG]
[IMG]local://upfiles/3652/D1781147563D46CA931B36262E117235.jpg[/IMG]
[IMG]local://upfiles/3652/4CF4C45B5C54426FB6A38771CBB6D5CD.jpg[/IMG]
Old Oct 8, 2005 | 12:56 PM
wicked_outlander's Avatar
ORIGINAL: derf
car is bitching w/ the new intake and filter....lol. have your car recognize it by re-setting it. or maybe you messed uP W/ B.O.V.
Old Oct 10, 2005 | 02:42 AM
ORIGINAL: derf
it should be fine then. try reseting the ecu. jus disconnect your neg batter terminal for a couple minutes, then let your car idle for 7minutes before you drive away and see if that fixes it.
Outlanderishness
Oct 20, 2019 05:09 PM
Iansilv
Jan 2, 2013 01:17 PM
c577
Oct 16, 2007 06:38 AM
wega
Sep 15, 2007 07:56 AM
darknigh7th
Dec 2, 2006 05:05 PM
