Knocking...
Old Mar 12, 2008 | 09:31 AM
Default RE: Knocking...
OUCH, that sounds like crap. But like the person that posted the picture said, it was the lifters. You may need to replace them. I would try an oil change and see if it quiets them at all
Old Mar 12, 2008 | 10:03 AM
Eclipze's Avatar
How much does it cost to replace the lifters? I have tried using different oils and doesn't seem to have much improvement.
Old Mar 12, 2008 | 10:26 AM
Have you tried a compression test just to make sure its not an internal problem like the valves. I would also do that just to be absolutely sure its just the lifters
Old Mar 12, 2008 | 11:32 AM
Eclipze's Avatar
ORIGINAL: TheEngineer
I havent tried a compression test yet. Whats the normal range for each?
Old Mar 12, 2008 | 12:27 PM
You should probably be somewhere in the 170-190 range. And no 1 cylinder should be more than 14psi difference from the others
jeromedurham
Sep 26, 2005 06:24 PM
jeromedurham
Sep 3, 2005 11:13 PM
bterwilliger
Jul 1, 2004 01:54 PM
nailgrl25
May 25, 2004 09:32 AM
spyder-man
May 24, 2004 05:26 PM
