Knocking/timing!
Old 07-29-2006, 03:46 PM
93eclipsegsx's Avatar
Default RE: Knocking/timing!
then i dont know, because when i had a knock, it was at all rps and it was pretty loud.
Old 07-29-2006, 04:06 PM
ohhh it's a loud knock but sometimes when it's at idle the knock will go away for a few revolutions then it's back. That's why I thought it might of been the cam slapping the rockers due to bad lifters. I just got done rebuilding a 1990 240sx 2.4L, stock no mods which purrs like a kitten, so I'll have time to jump back on the eclipse
Old 07-29-2006, 07:43 PM
how is your oil pressure?
Old 07-30-2006, 09:44 AM
oil pressure is good, oil is squirting out the relief holes for the lifters at the end above #1 cyl. I just remembered one time when i was listening to the motor I revved the motor a couple of times and then it wouldn't idle. I turned it off and let it set for a few minutes then started it back up and it idled fine again. Last thing I can do is pull the head and oil pan and take a look.
Old 07-31-2006, 10:42 AM
have you checked the bearing tolerance?
marshmallow746
06-10-2022 10:20 PM
judien
03-09-2018 03:41 PM
sherk
03-05-2013 10:47 AM
8000RPMS
08-30-2007 05:49 AM
bigguy6f4
1st Generation
07-09-2007 05:45 PM
Quick Reply: Knocking/timing!
