Knocking/timing!
Old Jul 29, 2006 | 03:46 PM
93eclipsegsx's Avatar
Default RE: Knocking/timing!
then i dont know, because when i had a knock, it was at all rps and it was pretty loud.
Old Jul 29, 2006 | 04:06 PM
wb12859's Avatar
ohhh it's a loud knock but sometimes when it's at idle the knock will go away for a few revolutions then it's back. That's why I thought it might of been the cam slapping the rockers due to bad lifters. I just got done rebuilding a 1990 240sx 2.4L, stock no mods which purrs like a kitten, so I'll have time to jump back on the eclipse
Old Jul 29, 2006 | 07:43 PM
how is your oil pressure?
Old Jul 30, 2006 | 09:44 AM
wb12859's Avatar
oil pressure is good, oil is squirting out the relief holes for the lifters at the end above #1 cyl. I just remembered one time when i was listening to the motor I revved the motor a couple of times and then it wouldn't idle. I turned it off and let it set for a few minutes then started it back up and it idled fine again. Last thing I can do is pull the head and oil pan and take a look.
Old Jul 31, 2006 | 10:42 AM
have you checked the bearing tolerance?
marshmallow746
Jun 10, 2022 10:20 PM
judien
Mar 9, 2018 03:41 PM
sherk
Mar 5, 2013 10:47 AM
8000RPMS
Aug 30, 2007 05:49 AM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
