lifter so dam noisy
Old Aug 11, 2006 | 07:58 PM
Nubiebubie_GSX's Avatar
Default lifter so dam noisy
well i have read about the noisy lifter that are common with eclipse. This morning it was kind of nippy and when i started the car it was really loud plus my oil pressure was half way up there. Is it normally loud when the weather cold or engine is cold.
Old Aug 11, 2006 | 08:57 PM
Default RE: lifter so dam noisy
Yes uits usually loud when its cold
Old Aug 11, 2006 | 09:53 PM
yah.. it just surprise me since i know my lifers tick. This time it sounded like extra loud, so i was like wtf i can't have bent valves. Well its quiet down now but my retarded gas smell is back. Can't figure where that leak is the top of the fuel pump is all rusty lookin.
Old Aug 11, 2006 | 10:24 PM
bent valves means a dead motor the car wont hold compression and wont run. so the tick is low oil pressure at startup or something too
Old Aug 12, 2006 | 12:12 AM
5Tizzle's Avatar
ORIGINAL: EMonz57
Dont mean to jack the thread, but lifter tick happens when there is just low oil pressure? is that the only thing that causes it? Because im getting it pretty much every time im at idle. I have a 7 bolt too...could that mean im getting ready to walk?
Old Aug 12, 2006 | 01:49 AM
ORIGINAL: Jeffisdecentttttt
ORIGINAL: EMonz57
oil changes always quiet it down... when oil gets low it will tick
Old Aug 12, 2006 | 08:18 PM
For me each time i check the oil the reading never the same. Some days its between the 2 marks other days it will be above the max mark. But its only ticks when it idle. During driving there no tick.
Old Aug 12, 2006 | 09:29 PM
idle= less oil pressure.
checking your oil means you have to do it before the car has been running other wise the levels are not accurate anyway
Zox
Mar 25, 2009 03:45 PM
Maximus99
Apr 12, 2008 10:14 PM
50ul }{4ck3r
Apr 25, 2007 10:30 AM
tunes
Apr 6, 2007 08:22 PM
galantgone
Aug 28, 2006 01:10 AM
