Little Heat, '97 GTS
RE: Little Heat, '97 GTS
mine was weak with heat until i figured out how to set it the right way and that if you have the vents on full circulation it'll mix hot and cold air, but if you close them half way it'll do just hot air, but if it doesn't put out any heat with messing around with all of that, then you probably have a thermostat issue.
