Little Heat, '97 GTS
Old Oct 23, 2006 | 01:24 AM
OldSchool's Avatar
Default Little Heat, '97 GTS
The heater does not seem to put much heat out. Is this the same for everyone? Especially in defrost mode it does not do well.
Old Oct 23, 2006 | 02:12 AM
5Tizzle's Avatar
Default RE: Little Heat, '97 GTS
maybe your thermostat is opening too soon and the coolant doesnt have a chance to get very hot...
Old Oct 23, 2006 | 10:00 AM
OldSchool's Avatar
The temp gauge when warm is usually straight across in the middle of the sweep. Where is the needle on anyone else with the turbo 2.0 on your gauge?
Old Oct 23, 2006 | 07:53 PM
Nubiebubie_GSX's Avatar
The middle during regular drive, but highway it goes a tiny bit higher than the middle.
Old Oct 23, 2006 | 11:21 PM
OldSchool's Avatar
Is there another elctric heater that compliments the standard heater core? Maybe a valve that sticks and does not open the heater core all the way to circulate the hot water?
Old Oct 24, 2006 | 01:00 PM
almost sounds like a thermostat issue. Cuz i had a problem where all i got was cold air no matter what i set the temp to.
Old Oct 24, 2006 | 01:57 PM
98eclpsrider's Avatar
mine was weak with heat until i figured out how to set it the right way and that if you have the vents on full circulation it'll mix hot and cold air, but if you close them half way it'll do just hot air, but if it doesn't put out any heat with messing around with all of that, then you probably have a thermostat issue.
Old Oct 24, 2006 | 10:19 PM
OldSchool's Avatar
I get some heat, just not alot.
wsuweston
Dec 18, 2005 10:05 AM
ad37@verizon.net
Oct 24, 2005 06:58 PM
ad37@verizon.net
Oct 23, 2005 03:08 AM
EclipseGS
Oct 12, 2004 02:39 PM
markm
Jul 10, 2004 04:09 PM
