Loose Belt
Old Jan 20, 2008 | 09:06 PM
lhausi2's Avatar
Default RE: Loose Belt
there should be something bolted to either the p/s or a/c unti that has 2 screws that are formed like a T. i'm not sure where it is, i'm tryin' to find my haynes manual right now,lol
Old Jan 20, 2008 | 10:15 PM
chopper1's Avatar
Directly under the power steering pump, there is an idler/tension pulley. It has a bolt on the side to loosen and let the other one slide. The one that sticks out to the front of the engine bay is the one to tighten the belt.
If the pulley has been deleted from going bad, there are two bolts on the left side of the pump that you can get to through the pulley and one on the backside and the pump can be adjusted also.
The radiator overflow tank will need to be removedfor access either way
rklamka
Mar 15, 2011 08:37 PM
BrunoBoy650
Mar 21, 2007 01:40 AM
RamZet
Oct 17, 2006 02:31 AM
97GSpower
Feb 11, 2006 09:35 AM
t4_gsx
Dec 18, 2005 08:45 PM
