loss of power... please help
Old Jun 26, 2007 | 06:01 PM
97spydergs's Avatar
Default loss of power... please help
need help diaognosing my problem... well first off it started sunday afternoon. i was driving along and went to down shift and found that i have a considerable loss in power. it also smelt like raw gas while i was in od but only when it was bweing lugged. so yesterday i checked the spark plugs those are all in decent shape as i replaced them less than 9k ago, they are densos, next i checked the compression it was an even 170 across all 4, then i disconeected the plug wires and tested them they were all less than the 50k ohms relace limit, i too had changed those les than 9k ago. i havent checked my fuel pressure. could that be a main cause. it still runs fine just a lack of hp from 3,000 rpm up.
thanks for your help
Old Jun 26, 2007 | 08:40 PM
I Drive Naked's Avatar
Default RE: loss of power... please help
When was the last time the fuel filter was changed?
It might be stopped up causing a drop in fuel pressure.
Old Jun 26, 2007 | 08:45 PM
silvercoupe97's Avatar
The gas smell, do you smell it through the exhaust or from the engine bay? If it's from the exhaust, I'm going to say that the spark plugs aren't lighting up the mix as well as it should. What type of Denso's are these? Perhaps the wires have started to break down. Check the wire boots for arcing also.
Was your car doing this before you changed out all that stuff?
Old Jun 27, 2007 | 01:49 AM
TurboH22's Avatar
I'll still changed the plugs just to be certain.
Old Jun 27, 2007 | 10:19 AM
97spydergs's Avatar
thanks for the help. yesterday i changed the fuel filter and the spark plugs and that seemed to do it. i also checked the fuel ressure it was 50 at idle and when i gave it the gas it droped to 40. is this normal i know some drop is normal but is that much accetable.
outlander123
Mar 2, 2024 02:51 PM
jdohe
Dec 12, 2010 07:00 AM
driftin2u
Oct 22, 2007 05:22 PM
Buckeyejack
Feb 24, 2005 07:28 AM
Buckeyejack
Feb 22, 2005 04:44 AM
