low oil
Old Mar 13, 2006 | 06:49 PM
Default RE: low oil
ORIGINAL: eclipsed4u
ORIGINAL: TheEngineer
drain it all, then fill'er up. i have never been a fan of adding oil in between oil changes
to me as long as its under a quart adding some is ok. It really won't effect anything. I guess it also depends on how long its been since the last change. after 1500-2000 you might as well do it.
if your oil is low and you are under 1500 miles since your last oil change....then you need to get that oil leak checked
If you have a turbo car you should change it before 3000 anyway...at full boost you burn oil, every turbo car blows some black smoke under full boost and between hard shifts. unless you have a catch can I am pretty sure those eliminate that
Old Mar 13, 2006 | 08:52 PM
novetek's Avatar
Default RE: low oil
I had it looked at this tune up place next to my work and they said it was my oil pressure switch and a sliced gasket. so thanks for the input but i do know when to change my oil i know that much hahahah thanks
Old Mar 13, 2006 | 10:19 PM
Default RE: low oil
ORIGINAL: novetek
youd be surprised how many people are lazy about there oil and dont keep up on it and do it on time... that is why I do mine early.
I drive a few hundred miles and start feeling like it has been forever and I go change it...always ends up being like 1500Miles or so lol
Old Mar 14, 2006 | 12:20 AM
slow420a's Avatar
Default RE: low oil
ORIGINAL: novetek
YEAH ILL PROBABLY CHANGE MY OIL ITS N NEED OF A TUNE UP I WAS JUST WONDERIN IF I SHOULD JUST ADD A LIL THANKS ALOT
I think your caps button is stuck down too, you might want to check that also.
m&t's_mit_99
Jul 16, 2017 10:24 AM
ronnie Galant 02
Aug 8, 2008 04:20 PM
MATMEG
Mar 23, 2008 02:02 AM
aowen2
May 29, 2007 09:19 PM
FlipNNVH
Oct 11, 2006 12:52 AM
