Is my boost gauge set properly
Old Oct 30, 2007 | 07:13 PM
nyc95gst's Avatar
Default Is my boost gauge set properly
Ok, so my boost gauge is t-off at my manifold. With my MBC open, I am getting readings of like 5-6psi, but I was told stock was like 7 or 8. Is it possible that the pressure is off becoz of where it's t-off?
Old Oct 30, 2007 | 08:49 PM
get435's Avatar
Default RE: Is my boost gauge set properly
What vac line are you coming off?
Old Oct 30, 2007 | 08:52 PM
You have a MBC? if that is correct then you cant run stock boost since the MBC overrides it
Old Oct 30, 2007 | 09:04 PM
nyc95gst's Avatar
But I can go less than stock?
Old Oct 30, 2007 | 09:22 PM
dsm1990gsx's Avatar
ORIGINAL: nyc95gst
Why?
Old Oct 30, 2007 | 09:31 PM
get435's Avatar
ORIGINAL: EMonz57
Over rides what? the wategate yes this is true but if the mbc is open all the way it should be reading more than 5-7 psi.
edit i ment it will not let boost hit the wastegate intil mbc spring is opened.
Old Oct 30, 2007 | 09:32 PM
Natedogg89's Avatar
ORIGINAL: nyc95gst
No the wastegate opens at 6 or 7 psi without any kind of boost control. Where do you have it T'd? It should be in the upper right corner of the engine off the FPS i think.
Old Oct 31, 2007 | 05:31 AM
is this boost gauge in metric or what and is it digital? my point being... how easy it is to say it reads 5 I cant tell exactly what hash line its pointing at , you know what I mean. He is running off the spring obviously and only reading like 1 PSI less than its supposed to lets think why that may be? Personal eyes not seeing it because it can be tough to count harshlines, a kinked VAC line running to the gauge, the distance of the line to the gauge and where it is "T" off. I think it is obvious there is no problem other than his boost controller is all the way out
Old Oct 31, 2007 | 06:35 AM
I agree with emonz. When its all the way open all its doing is running off the wastegate. So its fine. Are you able to turn the boost up is the question...oh and the reason that a car stock usually will run around 8psi is because of the stock BCS that it has.
Old Oct 31, 2007 | 10:22 AM
nyc95gst's Avatar
Ok, well it is running on the middle line. Is this correct?
I kept the MBC open so I could simply run stock boost which from talking with Engineer should not go lower than 8psi.
I adjusted some hoses and hose clamps, disconnected my battery and fixed my BOV return hose. It looks like I am running around 8psi now.
Emonz you are correct, my gauge is not digital so I am forced to read the hash marks. It is tough, but it looks about right now.
I will give it another run to see if I maintain stock level boost then see if I can get any increase from my MBC.
Thanks all
malikrausdeen@yahoo.com
Jul 22, 2013 07:27 AM
wolist
Jan 29, 2013 08:59 PM
nwcjc
Oct 6, 2010 12:41 PM
burnmyeyes
Jan 2, 2008 09:04 PM
