need help with a clutch problem
my clutch the other day worked fine and then i went out for lunch and it seemed odd and when i left school later it drove and then 5 minutes later my clutch got more and more play in it and then finally it would just go to floor and not do anything i figured it was a air bubble so i bled it and then it worked fine great right and then i drove around for an hour and then went somewhere it sat for another hour and then went home came home and 30 minutes went to leave it started got to the end of my drive way 10 ft away and it wouldnt go into first and then it did the same thing as before checked my master and no fluid was in there i figure its a hole but how does one just appear from nothing?
Follow the line to the slave and also check your pedal for signs of fluid. You probably have a resevoir by your slave cylinder that could be leaking, well, any of the lines could be. If they aren't leaking at the junction points, check for lines that are rubbing or cracked. That's the only explanation for the missing fluid.
depends on how old the lines are and how they've been taken care of before you got it and so on and so on or you have have just had a freak accident where a line or something might have rubbed up against or hit something it wasnt supposed to and got a nick in it...hope you can find the problem man...just follow those lines b/c if its leaking down that much then chances are somewhere on the engine you'll have hydrolic fluid...good luck man
wicked2407
Oct 25, 2006 06:07 PM
