OBD1 or OBD2?
Old Dec 26, 2007 | 10:35 AM
Gstfat's Avatar
Default OBD1 or OBD2?
is my car obd1 or obd2?i tried to put on a obd2 machine and it didnt read my car
Old Dec 26, 2007 | 10:55 AM
Natedogg89's Avatar
Default RE: OBD1 or OBD2?
did you turn the key to the "on" position? Not accessory but the next one. I'm pretty sure our cars are obd2
Old Dec 26, 2007 | 10:58 AM
tjbiker031's Avatar
it should be ODB2....read the directions on how to use it, maybe your using it wrong and dont know it.
Old Dec 26, 2007 | 12:06 PM
your car is OBDII. All 96+ cars for that matter are
Old Dec 26, 2007 | 06:54 PM
Gstfat's Avatar
yeah i did that,and it didnt read it,i also have a greddy auto timer installed,could that be the problem?
Old Dec 27, 2007 | 10:29 PM
TheAdvocate's Avatar
I worked on a talon that had a problem reading it.. It was because a fuse got pulled for the security and that fuse also kept the obd2 scanner from connecting to the ecu.. So check and make sure all of your fuses are in under your dash...
Arch
Jun 29, 2009 07:13 AM
Justin97
Jan 10, 2009 04:20 PM
LOWRIDER60
Apr 6, 2008 09:18 PM
pguignier
Dec 26, 2006 02:52 AM
RoryH
May 5, 2006 09:24 AM
