Pedal stays to the floor
Old Sep 19, 2008 | 12:35 PM
Scubba.steve's Avatar
Default Pedal stays to the floor
Ok, so i posted another thread about which clutch i should go with. But is there a possibility my clutch is good and something else is wrong. Car grabs in all gears except 1st and reverse. And everynow and then the clutch pedal will stay down to the floor. Does this sound like the symptoms of a bad clutch? Or a bad master and fork?
Thanks
Old Sep 19, 2008 | 02:02 PM
estraw's Avatar
Default RE: Pedal stays to the floor
check to make sure theres fluid in the master cylinder and bleed the hell outta it.
Old Sep 19, 2008 | 02:31 PM
if its getting stuck then its probably the master cylinder...or its getting stuck on the carpet, haha.
Old Sep 19, 2008 | 08:24 PM
dsm1990gsx's Avatar
Check the fluid and bleed it first. Also check the slave and mastercylinder for leaks.
y26
Sep 29, 2013 01:43 PM
rnorrell1
Oct 11, 2008 12:21 PM
03outlander
Sep 16, 2008 01:15 AM
salazar44
May 16, 2007 01:09 PM
EcLiPsEGrRL29
Sep 29, 2005 02:59 AM
