Po303 misfiring, power loss, and rough low rpm
Old Apr 19, 2008 | 04:06 AM
neurocrash's Avatar
Default Po303 misfiring, power loss, and rough low rpm
Greetings,
I am hoping that someone can help me with the diagnosis of my 1999 Mitsubishi Eclipse GSX.
OBDII reports diagnostic code Po303 - misfire in cylinder 3
Fairly smooth at idle and high revving when out of gear
Revving is always rough at low portion of rpm curve
Misfiring at low rpms when in or out of gear
Rough with power loss when in gear, especially under load or with heavy throttle (from start, uphill, or when floored)
Will drive almost normally if I'm _very_ gentle with the gas pedal
Flooring it when in gear results in deep low tone, rough vibration, and flabby power
Can anyone make a suggestion based on my symptoms?
Thanks!
Old Apr 19, 2008 | 08:34 AM
Default RE: Po303 misfiring, power loss, and rough low rpm
change your spark plugs and wires and that will probably fix the issue
Old Apr 20, 2008 | 12:03 AM
neurocrash's Avatar
Any idea whether it could be a fuel injector?
Old Apr 20, 2008 | 05:41 AM
Kaede.Noir's Avatar
not really... its either that or the coil pack... trust the engineer
Old Apr 20, 2008 | 08:43 AM
dsm1990gsx's Avatar
Injectors and coilsusually aren't a parts that fail often, listen to TE and change your plugs and wires.
Old Apr 20, 2008 | 09:01 AM
TheAdvocate's Avatar
I had the same thing.. Except it was misfire on cylinder 1.. Ended up being the spark plug wires.
Old Apr 20, 2008 | 01:46 PM
neurocrash's Avatar
Great! I already ordered plugs and wires, but just wanted to make sure in case other parts might be necessary.
Old Apr 20, 2008 | 06:39 PM
neurocrash's Avatar
And the winner is... Spark plug wire #3
Changing plugs and wires solved the problem. Thanks!
Old Apr 20, 2008 | 07:43 PM
darknigh7th's Avatar
yeah i had the problem of oil getting into my number 2 cylinder due to a torn sparkplug boot, andwas causing a bad misfire, so finally i replaced the wires, cleaned the oil, ran like a champ.
Old Apr 20, 2008 | 08:04 PM
glad to hear it.
WackJobRacing27
Dec 28, 2020 09:15 PM
WackJobRacing27
Aug 18, 2013 02:14 PM
Buzzer_k
Jul 22, 2013 01:00 AM
jdohe
Dec 12, 2010 07:00 AM
Fullysickmitsu
Dec 4, 2007 06:52 PM
