Pulley making a noise
Does anyone have a problem with their stock pulleys making a whistling noise. I'm not sure what pulley it is, but it sounds like one of them is loose. I have adjusted them by tightening and untightening the belt tensioners and it doesn't seem to help. I also sprayed the belts with some lubricant but nothing works. It usually makes this noise when I first start my car. It sometimes goes off when I turn the fan off and sometimes or straighten my wheel, which makes me think its my power steering or A/C pulley. I was thinking of replacing my pulleys with a Unorthodox Racing kit, but am not sure what to do at this point. Any suggestions.
RE: Pulley making a noise
Just replace em. They're prolly are the original belts, so it's about time they were due for a change. They're between 5-8 years old now, and if you've ever seen a tire that's 5-8 years old, then you know what dry-rotting is!! But yeah, the power steering belt always chimes a bit when you lock too much, it's always been a pet-peeve of the eclipses(not galant's though[:-]).
The belts themselves appear to be ok, and I believe they have been changed, although I'm not sure because I bought the car used. Do you know the average life of these belts. I have about 94,000 miles on my engine.
phils06gt
04-18-2012 12:10 PM
