question about ecu
Old Jan 23, 2005 | 03:49 PM
1398spdr's Avatar
Default RE: question about ecu
see if you can get some codes pulled.....
Old Jan 29, 2005 | 12:15 PM
jojawake's Avatar
The engine does run rough just before in cuts off. I got a code of a malfunction coil when the check engine light was on. I replaced the coil, engine still did the same thing. But now no codes are coming up when the engine cuts off. also when the check engine light is on the engine runs good. As soon as the check engine light cuts off the engine starts missing and cuts off. This is a good one ! but its real. Thanks
Old Jan 29, 2005 | 07:16 PM
1398spdr's Avatar
id start by checking the battery terminal and making sure the wires are tight, make sure the plug wires are properly connected to the coil and spark plugs......... could be grounding out somewhere....... new plugs, new plug wires.........
Old Feb 21, 2005 | 09:37 PM
jojawake's Avatar
Thanks, It was the spark plugs and wires. Changed them out engine runs fine.
nyc95gst
Jan 18, 2008 01:25 PM
PooT_Nation
Oct 26, 2006 04:06 PM
superinflamo
Jun 17, 2006 01:49 PM
twinstealthytalon
1st Generation
Oct 12, 2005 10:53 PM
GreddyBooster
Sep 30, 2005 09:34 AM
