Radiator fan again :(
Old Jan 31, 2008 | 11:33 AM
bagaak's Avatar
Default Radiator fan again :(
hi guys, ok my radiator fan just stopped working on me. i tested it by connecting it to my battery, and to my surprise it still works. so me thinking that i can fix it, i bought a haynes guide (which is like my bible now) and i dont understand what i should check now. im a tad confused but what would you guys check next? and how would you check it. btw i have a 99 rs. i want to do it myself instead of having a mech look at it if its something like a bad relay or something stupid like that instead of them charging me a arm and a leg to change 1 wire... or a sensor. thanks again
Old Jan 31, 2008 | 11:45 AM
PappiDread6's Avatar
Default RE: Radiator fan again :(
Fan relay fuses located under the hood, wiring to and from the radiator its self. Also tryin running you A/C see it it kicks on or not.
Old Jan 31, 2008 | 12:05 PM
bagaak's Avatar
i tried all the fan solutions and it doesnt kick, btw can you show me a diagram of where it should be? is it in the fuse box? im a noob at this
Old Jan 31, 2008 | 12:08 PM
RCJr9186's Avatar
you know where the fuse box is under the hood right? should have a diagram sticker right on the top of it. should say "radiator switch/fan" or something like that.
Old Jan 31, 2008 | 12:11 PM
bagaak's Avatar
ok just checked that one and the radiator fuse is there but when i look on the little black fuses (im thinking these are the relays) im missing the first three they all say radiator fan h and somthing but i do have the last black fuse thingy that says radiator fan low.
Old Jan 31, 2008 | 12:17 PM
RCJr9186's Avatar
soooo leme get this straight.
you are missing 3 fuses that have to do w/ the radiator fan, right? do you still have a problem?
Old Jan 31, 2008 | 04:21 PM
yes the relays should be located in the fuse box. Usually they are the larger parts in there. If its not there then thats most likely your problem
helidix
Nov 23, 2007 05:50 PM
X Treme
Aug 24, 2007 12:06 AM
salazar44
May 16, 2007 01:09 PM
hoosierdaddy_87
Jul 5, 2006 03:05 PM
eclipseonjuice
Feb 12, 2006 01:11 AM
