rpm problem
Old Dec 9, 2006 | 12:37 AM
grim0reaper0's Avatar
Default RE: rpm problem
no my light isnt on but u think i should still get it computer checked?will disconnectin the battery make the engine light leave if so will da code still be in computer
Old Dec 10, 2006 | 03:29 AM
bump
Old Dec 10, 2006 | 06:10 AM
racerx55's Avatar
[sm=alcoholic.gif]
Old Dec 10, 2006 | 06:57 AM
silvercoupe97's Avatar
Since there was no background about your car, I would say to check the relays on the firewall. The first one is fuel relay, the second is the ASD, and the third should be the EATX relay (transmission relay). Have you checked your fluid? If not, check it and note the smell and color and...look for pieces of metal. If it's not any of those above, the last three things that it might be will be costly...the TCM, tranny solenoids, and the tranny itself. That's assuming that it is in limp mode.
BTW OP, limp mode is when the transmission stays in 2nd gear. That is a safety for you tranny and it's only to "limp" you home or a garage, so if you're driving around with it like that....yikes.
litza02spyder
Nov 27, 2010 08:20 PM
ilko100us@yahoo.com
Mar 2, 2006 06:32 PM
eclipse2gnt03
Jan 18, 2004 04:00 PM
eclipse2gnt03
Nov 20, 2003 06:24 AM
eclipse2gnt03
Aug 1, 2003 01:29 AM
