speedo acting crazy
Old Nov 17, 2008 | 08:19 PM
xhtby21tx's Avatar
Default speedo acting crazy
okay the last couple of days my cruise control was going up and down the speed im like okay then today i was driving home and my speedo was like 20 then 0 then idling up and down it is weird what can b the problems guys please help oh yea i have no check engine light on or nothing
Old Nov 18, 2008 | 04:12 AM
silvercoupe97's Avatar
Default RE: speedo acting crazy
ORIGINAL: xhtby21tx
Like that was hard to like read. Like you might want to like use punctuation and like take a v-breath. Like seriously.
So, your cruise is acting up. It accelerates and decelerates on its own. The last part I don't understand at all. Are you having issues with your speedo or idle?
Check for vacuum leaks. Does the motor rev on its own while at idle? What was the last thing done to your car?
Old Nov 18, 2008 | 07:18 PM
xhtby21tx's Avatar
well my speedo is acting up. its not reading the right speed it goes up and down when i drive. the only thing i did to my car is change the fuel regulator and fuel soilnied thats it
Old Nov 19, 2008 | 05:15 AM
Ok, so your speedo is just bouncing up and down and your car is not accelerating and decelerating, correct?
You could have a bad connection with your speed sensor on the transmission. Is your car an automatic or manual? Regardless, the speed sensor is on the transmission. Two more things could be causing this and one is the speedometer cluster itself and the other is the ECU. The ECU is the more expensive of the three, so start with the other two first. Start with the speed sensor or gauge cluster. The gauge cluster can be bought on ebay and the likes pretty easily.
calgon92
Aug 14, 2008 06:21 PM
modmyes
Apr 30, 2008 08:15 PM
matt02708
Apr 27, 2007 02:24 PM
djfrog2001
Jan 15, 2007 10:58 PM
baker_sk8er37
Feb 13, 2005 11:22 PM
