Speedometer problems
Old Apr 19, 2007 | 12:46 AM
kikoavy's Avatar
Default Speedometer problems
Ok i just had my engine changed, I have a 1997 eclipse rs the old engine was knocking really bad and didn't feel like dealing with it. Now i found a used engine from a 95 eagle talon same as the 97 eclipse 420a n/a with 71k on it and installed that one. The problem is that the speedometer is 10 m/h ahead meaning, for example the speedometer reads 60 m/h but i'm actually only going 50 m/h. i had a friend drive at the same speed on the highway. So does anybody know what's causing the speedometer 10 m/h ahead?
Old Apr 19, 2007 | 02:41 AM
darknigh7th's Avatar
Default RE: Speedometer problems
mine did that when i pulled out the indiglo gauges, i just kinda played with it for the needle till it worked.
Old Apr 19, 2007 | 03:27 PM
austinw23's Avatar
i have a gst 97 with the same problem people were telling me it was my tires but i have had multiple sets of tires snow tires street tires old ****ty one to burn but it always reads 10 mph faster i guess its just the way the gauges are setup i dont really know what else it could be
Old Apr 19, 2007 | 04:40 PM
kikoavy's Avatar
Yea maybe its the gauges the previous owner put that indiglo gauges on it. Plus my temperature is stuck like a 1/4 down but itcomes up when its hot it never goes all the way down though when it's cold. I always have to take the instrument cluster out then reset it again.
Old Apr 19, 2007 | 04:42 PM
Dusty Eclipse's Avatar
Yea, thats what makes my 3G **** me off. I put Indiglos in... and ****ed with everything... Now its just... a mess.
Old Apr 20, 2007 | 05:16 AM
98eclpsrider's Avatar
mine reads 2 mph faster when i got past a speed sensor things we have around here, but my buddies new kia does the same thing, so we think it's the sensors on those things, and plus when i got my new speed sensor in, i got it calibrated to the right speed. so if you have a little bit of change it might be in need of calibration.
Old Apr 20, 2007 | 05:23 AM
silvercoupe97's Avatar
ORIGINAL: kikoavy
Did you reuse the old speed sensor or are you using the "new" motor's speed sensor?
98eclpsrider, you have aftermarket rims correct? That could be your issue, or was your issue.
Old Apr 20, 2007 | 05:26 AM
ORIGINAL: silvercoupe97
ya, but they're only an inch above stock now, when i get my new rims i'll have to go back because i'm getting 18's, and inch up from what i have now, at it also depends on the tires as well, if you have super low pros or just a low pros or regular ones.
Old Apr 20, 2007 | 05:49 AM
Well, the size of the rim doesn't matter as long as you stay within the stock, overall, diameter..to include the tires. If your car originally came with 215/50/17, 205/45/18 is fine...I believe that's correct, it's close enough for the point. If you're even a tad under or over, your speedo will start to be off and noticable after and around 50-55mph.
Old Apr 20, 2007 | 05:52 AM
I always suggest using an online wheel calculator when buying new ones. I've got a couple of them, I found this one pretty quickly, so here it is...
http://www.discounttire.com/dtcs/infoTireMath.dos
Use this one for the next buy, unless you stay with the overall size that you have now that is.
rickywhite09
Oct 8, 2012 08:13 PM
jp2000
Jan 1, 2012 05:21 PM
yoboricua
Aug 17, 2004 05:15 AM
blumsoccer
May 23, 2004 11:23 PM
IDriveFast
Jul 2, 2003 01:26 AM
