Stalling problems
i have a 99 spyder 2.4 engine and it keeps stalling when you come to a stop.... it starts right up fine and can drive fine but after a while it stalls when you come to a stop and sometimes while driving.. ive changed the spark plug wires and the spark plugs and they didnt seem to help much... any advice? and it also comes out with a code p0446
P0446 - EVAP System Vent Control Malfunction:
Vent Solenoid Valve (VSV) testing
1.) Disconnect VSV electrical connecter. Check resistance across Purge Solenoid Vavle (PSV) terminals. Resistance should be 17-21 ohms at 68 degrees F
2.) Mark and disconnect vacuum hoses from VSV. Connect hand vacuum pump to PSV nipple closest to terminal end of solenoid. Connect jumper wires between PSV terminals and battery positive terminal and battery negative terminal.
3.) Apply vacuum with battery voltage applied. Vacuum should hold. Disconnect battery voltage and apply vacuum. Vacuum should leak.
