Starting Issues with 97 Eclipse GST
Old Jun 11, 2005 | 06:11 PM
FireDoc's Avatar
Default RE: Starting Issues with 97 Eclipse GST
Let us know how it goes!
Old Jun 14, 2005 | 08:36 PM
mvoltage's Avatar
Got a new battery. Works great now
Old Jun 14, 2005 | 09:12 PM
wicked_outlander's Avatar
ORIGINAL: mvoltage
so...its the battery then???[:-] ( hopely that batt. will last )
Old Jun 14, 2005 | 10:12 PM
TurboDreamer's Avatar
try by cleaning the burners, if not then check your starter.
Old Jul 31, 2014 | 03:34 AM
Charlie Stempniak's Avatar
Default I was going to suggest the battery all along.
Glad you got it fixed. Make sure battery cable arent shorting anywhere. Like an open cut wire or something. Also clean the connections and make sure there snug. Make sure your alternator has the grounds on them. Have the shops that checked your battery check your alternator and see how much it's charging. Also are you leaving the radio on and draining the battery without running the car alot? And try getting a battery with more cranking amps both cold and regular. Do you have an aftermarket sterio or amp? Ok well good luck. Also 5 year battery and replacements free sounds like a great deal to me.
wyatt0081
Dec 1, 2013 09:59 PM
13adman
Apr 17, 2010 06:31 AM
JoeK
Apr 5, 2010 11:31 PM
kimbok
Sep 29, 2008 02:54 AM
DigitalKate
1st Generation
Oct 1, 2005 04:52 PM
