Old Feb 18, 2006 | 06:51 AM
GST's Avatar
GST
Default Suspension
sorry, i'm new to the "fast" world, and i would like to know what does suspension do for the car.. would it make the car smoother? faster? performance wise.. what is a good price for it? thanks.
Old Feb 18, 2006 | 10:05 AM
Default RE: Suspension
ORIGINAL: GST
price cant be answered it can range from a few $100 to a few $1000 suspension in a DSM is an important upgrade to me. It can hwlp with traction but mainly handleing youll be able to push the car alot harder into and out of corners. it wont make the ride smooth because generally you lower the car and stiffen everything up and that means you feel ever bump (it is very much worth it though) IMO it make a car alot more fun to drive.
Old Feb 18, 2006 | 10:41 PM
GST's Avatar
GST
ohhh.. cause i also heard from people.. suspension is important in racing. thanks
Old Feb 19, 2006 | 12:09 AM
slow420a's Avatar
Suspension is just as important as a motor in racing. A good suspension is key to getting traction off the line in a drag, it helps the car leap in and rocket out of truns faster in autocross, and give controle slides in drifting. What i recomend is that you first fuiger out what you want from the car to meet your needs.
Old Feb 19, 2006 | 12:51 AM
Sanguinius's Avatar
Yeah suspension will play key roles in all types of racing. Not to mention changing the way your car handles even on daily driving. Different setups for different things so like slow said figure out what you want to do and then research what is good for that type of driving. Just take a look at pro races. Each car is set up differently suspensionwise. And slow what YOU need to do first is either A.) Learn how to spell or B. Find us a spellchecker for the forum LOL
Old Feb 19, 2006 | 08:25 PM
pedroven88's Avatar
I have Coilovers on my car and on every little bump that I hit I makes a big thud noise. Should I raise it a little more or is it that I need new Shocks?
Old Feb 19, 2006 | 09:47 PM
badass91hatch's Avatar
well if you have stock shocks/struts you should have them replaced with an aftermarket set made for lowering in the first place.that should take care of your issues
Old Feb 19, 2006 | 11:17 PM
ORIGINAL: badass91hatch
better get a camber kit too or you will have some sad looking negative camber going on
miche77e
Oct 31, 2005 12:16 AM
Galantz01
Feb 19, 2005 04:43 AM
mrgordijev
Feb 5, 2005 05:58 AM
ivanejackson
Oct 11, 2004 12:07 PM
jacek
Jun 16, 2004 07:02 PM
