throttle body leak.
Old Oct 5, 2008 | 01:20 PM
needsagst98's Avatar
Default RE: throttle body leak.
and permatex smells bad lol. i had a brand new tube that i forgot about so i used it.
Old Oct 5, 2008 | 08:37 PM
okay so i messed around with the tps and i cant get my idol any lower then 900rpm. on a warm start up itll be like 750 to 800rpm and then after i hit the gas it wont drop down past 950rpm, and also i have a little play in the gas pedal. is there anyway to fix that?. and ive always had that and it was fine. but i want to fix it becasue its anoyying now.
Old Oct 5, 2008 | 09:04 PM
estraw's Avatar
it sounds like your throttle cable needs adjusted
Old Oct 5, 2008 | 09:20 PM
how do i adjust it?.
Old Oct 5, 2008 | 10:28 PM
estraw's Avatar
theres 2 bolts on the back of the intake manifold, loosen them and pull the cable/bracket whichever way it needs to go.
Old Oct 6, 2008 | 06:54 AM
Either that or like i said in the begining, make sure you wound up the spring on the TB that the cable connects to. It is probably one revolution off.
Old Oct 6, 2008 | 12:32 PM
yeah, it was when i first put it on i was pissed. lol. then tightened it up again. i dont think the iinner spring(green one) is the same tightness. should they be equally tight?
fustball
Oct 26, 2015 08:03 PM
magno_313
Jan 16, 2005 04:15 PM
Davet2
Nov 18, 2004 01:17 PM
JimmyB
Jun 11, 2004 07:52 PM
