trans fluid
Old Nov 7, 2008 | 06:22 PM
shadowmancer's Avatar
Default trans fluid
i need mine changed because the jack*** before me that had the car overfilled it. i hear theres a greatATF that mitsubishi makes for automatic trans. does anyone know about it and where i can get it. do i have to go to the dealer for it and is ir costly?
Old Nov 8, 2008 | 08:04 AM
Default RE: trans fluid
you dont need anything crazy for auto tranny. You can just get normal tranny fluid from any auto parts store and it will be fine
Old Nov 8, 2008 | 08:57 PM
silvercoupe97's Avatar
Wait, if you have the 420a with the a604 tranny, then stick with the Mitsu ATF. The Chrysler a604 is very finicky with it's fluids. If you do happen to put in any general fluid, six months from now, you will most likely go into limp mode with any "spirited" driving. If not limp mode, then you will have issues with shifting. Been there done that, don't follow suit.
Old Nov 9, 2008 | 12:26 AM
yea. well i wana stick with the mitsu ATF because i hear its smoother than the the chrysler and i dont really wana put some random trans fluid in. to stay with the mitsu fluid do i have to go to the dealer? and is there a filter i have to change too for the tranny fluid?
Old Nov 9, 2008 | 05:40 AM
I assume they're both the same since either is recommended...Mitsu for the Eclipse and Chrysler for the Avenger/Sebring. Both cars have the 420a and the a604. Your choice really. I suggest calling both dealerships to find the less costly of the two.
The filter is a good thing to change out, but be sure to have the tranny flushed too. Not all shops will flush and change the filter, most do one or the other. Weird I know, but I've ran into that issue, so be sure to ask if they do both.
Clearing the pan of tranny fluid isn't the same as flushing the system and yes, those are dealer only fluids.
Old Nov 9, 2008 | 11:38 AM
oo arite. hmm. and so this isnt something i can do in my driveway? ill have to take it to a shop?
Old Nov 10, 2008 | 03:10 AM
ORIGINAL: shadowmancer
You can change the filter at home, but you'll need a machine to flush the old fluid out.
Old Nov 10, 2008 | 07:29 PM
oo arite thanks. and about ATF+3 and ATF+4, is that the stock fluid or what i should maybe get, i read around about those two fluids but get confused...
Old Nov 11, 2008 | 02:17 AM
ATF+3 is recommended for 95-97 a604, but the ATF+4 is fine from what I've seen and read.
Just a note, ATF+3 is what that tranny started out with. Your call. I'd stick with ATF+3, but that's just me.
Old Nov 11, 2008 | 12:32 PM
arite, thanks for your help
trainfun
Oct 10, 2019 04:58 PM
newoutlanderfan
May 27, 2013 10:47 AM
jcasaccio
Jun 6, 2006 06:14 PM
holdmyhandgary
Jan 4, 2005 10:48 PM
glennsafrit
Jun 21, 2004 12:00 AM
